Old 08-21-2009, 02:20 PM
Bobcat Bobcat is offline
Another possibility ... the Tilton uses a quad seal on the piston , which has a fairly low breakaway compared to the "O " ring seal that some of the others use . An O ring will actually stick to the wall of the tube if it isn`t used for a while and has to breakaway before it can slide . The quad seal will do that also , but to a much , much smaller degree . After you cycle the piston ( TOB ) a few times , the seal is lubricated and all works smoothly . Either way , it isn`t a huge problem as we built 1000`s of hydraulic cylinders with quad seals and all your Agricultural cylinders use O rings on the piston and rod .
If you don`t have some white grease on the sleeve , I am leaning toward that as the cause .This may be a dumb question , but I assume you have a pedal stop .... right ???? You do NOT want to over extend the TOB as there isn`t much SF on the max length Tilton gives you .
Bob
