Old 08-22-2009, 07:11 PM
SP01715's Avatar
SP01715 SP01715 is offline
Cobra Make, Engine: SPF1715, Roush Built 434 ci Stroker, Dart Block, Ported AFR 205 Heads... 561 hp / 547 tq, Former Roush Show Car, Completed and Prepped By Olthoff Racing.
Originally Posted by fsstnotch View Post
Sp, you forgot to mention one thing.... adding said tuners to boost performance doesn't hurt the economy. It boosts it!!!! With my 05 F250, I would lose 2mpg hauling a 3-4 ton car trailer. In my expedition, my mpg would be cut in half! Unloaded in a lifted F250, I average 19-21mpg and anywhere from 15-18 loaded depending on weight and terrain and such.
Me... I'd have a difficult time buying a Prius with 100k, but wouldn't even blink at a diesel with 100k.
As far as your wife and the new TDi, just make sure she follows the precaustions of any turbo vehicle. 1 minute for warmup and 1 for cooldown. Do that and change the oil at regular intervals and you won't have to worry about turbo failure. Diesel will last well beyond the typical lifespan of a gasoline car. I would even look into putting a turbo timer on it for simplicity reasons. Both my wife and I are diesel drivers, we've never had a problem finding diesel. I'm even tossing the idea of making my own!
Yep the tuner on my duramax gives me better fuel mileage as well. I also have an alarm with a cool down mode that I use after it is parked so the turbo gets to cool down a bit. I will be installing the same system on the Jetta. Thanks for the info, I appreciate it.
