I would lean toward the cam timing, I always degree a cam when installing so that I know the machining/manufacturing tolerances didn't thow them off. You can do a pretty accurate check with a valve cover off, but count on removing the front if it is off any. Use the cam card to check accuracy. Too tight of a valve adjustment can create similar issues as well.
WDZ
