Old 08-23-2009, 12:05 PM
Tom Kirkham Tom Kirkham is offline
CC Member / Sponsor
Originally Posted by Smokin427 View Post
...Timing and advancing (New MSD ingition, 16 initial 32 total (it is advancing))...
Sounds like your cam timing is a tooth off. Very easy to do if you are installing a timing chain while the engine is still in the car. I did it it my 67 Mustang in while I was in High School...And WOW did it run better when I fixed it.
This is probably not your problem but...
Your total timing is a little bit retarded. Typically FE should be about 36 degrees. Also at what RPM is the advance all in?
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
