Old 08-23-2009, 01:21 PM
blykins blykins is offline
Hydraulic is what most Cobra guys run and allows the most amount of tweak-ability (if that's a word).
The only issue with clutch cables is that they can stretch with higher performance clutch kits.
You can switch over as long as you feel comfortable with adding a clutch pedal that can use a clutch master cylinder. Also, the slave cylinder will have to be mounted in the trans tunnel.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
