Old 08-24-2009, 06:19 AM
zrayr's Avatar
zrayr zrayr is offline
Cobra Make, Engine: Fords
Originally Posted by Bob Malmen View Post
Good to hear from you Jerry. I'm having almost the same issue upon hard braking. Also when I come to a stop under normal braking the idle hangs around 1100 and then will come down to 900 after about 30 to 60 seconds.
After your comments my fuel pressure maybe to high at 9.5 psi? I have a holley with a return setup. Any thoughts?
I have seen 8 lbs as the upper limit for stock Holley needle & seat (non-supercharged application)
Z.
'65 K code Mustang
'66 Galaxie 500
