Old 08-24-2009, 01:51 PM
D-CEL D-CEL is offline
Cobra Make, Engine: SPF 239
Argess,
Hold on there brother! You're spinning the motor to 6600prm, in first gear (3.28/1) with a 3.07 rear gear and a 295/50 tire, and you can't tell if they are spinning? What does your speedo say? Do you have a limited slip dif?
Anyway,
Those tires suck so bad its hard to describe.
Take them off and set fire to them!
They have no redeeming qualities and shouldn’t be on a Cobra.
Once you’ve done that, go get a FULL set of Drag radials yes, FRONT AND REAR! I like the M/Ts but everybody makes them BFG, Nitto, M&H, take your pick.
All that you know about your Cobra will change, it will be much faster and safer.
Jason
