Old 08-24-2009, 02:17 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Argess View Post
It feels like first is geared too low, but yet, when I drive normally, first almost seems to high when I leave from a stoplight.
I am using a 3.07 differential with a Richmond Gear 5-speed (standard 1st gear) and a 428 FE.
You need to look at 1st gear multiplication to determine if you're geared right, too low or high. For a BB cobra, I've been told that you want between 8.5 and 9 . So, in your case, 3.27 (1st gear) X 3.07 = 10.0, so you might be geared a little too low, like you stated, however, you're not really that bad out of the ball park. I know some cars use the tremec 3550 with 3.27 1st gear coupled with a 3.73 rear, for a factor of 12.2, much more out of the ball park. I've run a wide ratio TL (2.78 1st gear) with the 3.07 rear for a factor of 8.53, which to me seems fine for drag racing as well as street use. However the richmond 5 speed is a true close ratio tranny, which my TL is not, and I had thought at some point I may replace the WR TL with a richmond 5 speed, but specify the 3.04 1st gear instead of the 3.27 if that was still available.
I have run a BB cobra with a close ratio TL ( 2.32 1st) with a 3.54 rear, factor of 8.21, which to me also seems fine for drag racing and street use.
You just can't put your foot entirely into it until you're moving somewhat, and on a drag strip, it's usually stickier than on the street.
I think you're fine.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
