Thread: Engine Ground
Old 08-25-2009, 05:54 PM
Argess Argess is offline
Glad you have the situation rectified. Lots of good advice from what I see. But I thought I'd like to add, why not move the battery to the engine compartment? Why?
1/ Only need a couple of short #4 cables
2/ no acid or acid fume corrosion of anything metal in the trunk, like the "floor"
3/ Lead-Acid batteries in a confined space? Explosive hydrogen gas may fill the trunk.
4/ Maybe a little easier to get organized when using jumper cables. At least no sparks near, or on, the gas filler tube to the tank in the event of an accidental bump.
5/ AND, if you have enough Hp, it can help keep the front down.....LOL.
But lots do it with no problems....just a thought
ps: one disadvantage to front mounting...at least in my case....I have to remove the right valve cover to change the battery
