Thread: Engine Ground
Old 08-25-2009, 07:00 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
I'm wiring my car now with a Ron Francis wiring harness. They are adamant in their directions as well as in their catalog that the frame should not be used for a ground. They strongly and repeatedly emphasize that a heavy ground cable should be run from the negative terminal of the battery directly up to the starter mounting bolt on the engine. From there you run a ground from the starter bolt to the frame, and start grounding the other items in the car accordingly.
