Old 08-26-2009, 03:54 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
The biggest problem with a bearing is you cannot lock the centre of the bearing to the gearbox shaft. This can result in the shaft turning on the inside of the bearing and as the bearing is made of high carbon steel and the shaft of alot softer material you will wear the shaft on the nose. Stick with a Brass spigot it will cause you less problems
