Old 08-26-2009, 05:23 AM
WKB's Avatar
WKB WKB is offline
Cobra Make, Engine: Harrison Cobra, SC540 Roadster
I have had a noise when the clutch pedal is pushed in. It sounds like a throwout bearing(the noise has been there pretty well from when the car was registered). The noise comes and goes, can be just audible to a horrible noise which sends a vibration through the gearbox, and goes away when in neutral and the clutch pedal is out. I am now thinking it could the spigot bush. But regardless what it is the gearbox needs to come out. To remove the gearbox the motor needs to removed from the car, so when it goes back in I want to 100% sure that the problem will not re-occur.
There is only one place I can get the spigot bush and I have one of these installed already.
That is my dilema, do I replace it with the same bush, or put a bearing in its place.
Originally Posted by Krait View Post
Warren,
BTW was it you talking to Roger Errington the other day?
Geoff,
If Roger is an electrical engineer who has worked with you before, that was me.
Warren
