Old 08-27-2009, 11:44 AM
Ron61's Avatar
Ron61 Ron61 is offline
There is another thing that I did when I used to put my cars in shows. I bought some packets of blue caps that have a small plastic insert that will latch them onto the bolt heads. You can get them in about any color around here to match whatever you are using as hose ends. They look great, but be sure to take them off before you drive the car far as they will shake loose and you will lose them. They are strictly a look type item.
Ernie,
Which nut did you try the WD-40 on? Hope you got the residue off your leg ok.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
