  #58 (permalink)
Old 08-27-2009, 09:05 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
I'm home now. Parts must have come Monday. I got it all together, I put everything away and surprise, I do not have release. It will try to drag the car when in gear and cutch pedal against the firewall when cranking the starter. It looks as if I need more travel with this disc. Same slave cylinder and so on, but when I watch from underneath it looks like the disc flexing as the last of my travel is used up. The slave cylinder rod seems to move just a little over 1/2". I installed this disk brass buttons against the flywheel as the picture on the box mentiones. Theat put the torsion springs towards the transmaission. Trans went in by hand, no pulling it in with bolts. I'm going to try a larger Tilton master cylinder moving from a 15/16" dia to 1" dia wich I have.
Mike H
