Old 08-29-2009, 06:25 AM
patrickt patrickt is offline
Originally Posted by mdross1 View Post
For the coil-over equipped cars,it is a must to have the cars suspension scaled.
That's good advice for almost everyone on this forum. You can rent a set of scales for the day from your local race shop and then it just takes a little time on the coilovers to get your corner weights right. There are no tricks to it, just remember to loosen up your sway bars, check your tire pressure, use a level floor, and put some weight in the driver's seat. It's actually a pretty satisfying task to complete -- just remember to tighten your sway bars up when you're done.
