Old 08-31-2009, 08:15 PM
d_ford's Avatar
d_ford d_ford is offline
Cobra Make, Engine: CSX4000, Shelby aluminum 496 ci FE
Argess,
The linkage looks like it's adjusted correctly. It does create smoke from the exhaust when I accelerate at all except very easy, that's when it pops and cackles through the exhaust. It seems to do it when the secondaries would be opening but when I disconnected the vacuum hose the should have eliminated the secondaries altogether. I used Jon's advice from Pony Carbs and timed it without using a timing light after I put the new carbs on. The carbs were replaced initally due to this issue and made a huge difference to the better as far as startup, idle and driving as long as I accelerate slowly.
I suppose anything's possible but the carbs were run on an engine and tuned before they were shipped to me and they never backfired after installation so I wouldn't have thought a power valve was out.
The valves were recently readjusted so they should be good to go. I have a new aftermarket distributor and wire set that I'm going to install tomorrow in case the dist. isn't advancing like it should and in case any of the plug wires are bad. I'm just tired of throwing parts at this thing with no results.
Doug
CSX4761
ERA #115 - sold
ERA #002 - sold
07 GT500
66 GT350 tribute
70 Mach 1
65 Comet gasser
