Old 08-31-2009, 08:46 PM
Argess Argess is offline
uh.....start at 10 Deg intial and work up....no need to start at zero (TDC). Engine will heat up very fast without enough advance. Find out your total advance and keep things under 38 total. Check advance is working by using timing light and giving it a small amount of throttle from idle. Timing should move smoothly. I don't like going past 2500 rpm with an unloaded engine
