Old 08-31-2009, 09:04 PM
cobred's Avatar
cobred cobred is offline
Cobra Make, Engine: ERA #698 428 Toploader
I dont think removing the vacuum hose from the carbs will eliminate the secondaries. They are controlled from internal ports. I think the hose only balances the opening so they work together under hard accelleration. There should be a small clip to remove to disconnect the vacuum pod from the rear shaft if you want to bypass the secondaries. I think.
