Old 11-30-2001, 06:12 AM
renaissance man's Avatar
renaissance man renaissance man is offline
Cobra Make, Engine: SMC Motorcars 289
Send a message via Yahoo to renaissance man
I have a 4-Speed Wide Ratio Toploader with a 4.10 rear end. A fifth gear is nice if you want to reduce noise but it's the sound of that 4-Speed at 70 or 80 mph that gives you that "NASCAR" sound!
Here are the specs on the Wide Ratio Toploader and a bit of how it works:
first second third fourth
Ratio: 2.78 1.93 1.36 1.0
HOW A TOPLOADER WORKS
In first-speed, the first & second-speed synchronizer sleeve is moved rearward by the shift fork. The sleeve engages the first-speed blocking ring, which acts as a cone clutch applied to the free-wheeling first-speed gear. This action speeds up or slows down the first-speed gear to match the speed of the output shaft. Further movement of the sleeve locks the first & second speed synchronizer hub to the first-speed gear by means of internal splines.
On engagement of the clutch, power flows through the input shaft & gear to the meshed countergear and thence to the first-speed gear. This gear transmits the power through the locked synchronizer hub to the output shaft. All other forward-speed gears are in idler motion, as they are driven by the counter gear, but they do not transmit power because they are not locked to the output shaft. All other forward-speed shifts are made in the same manner as the first-speed shift due to the constant mesh feature. The shift to the fourth-speed gear locks the third & fourth-speed synchronizer sleeve to the input shaft.
This allows power to flow straight through the input and output shafts.
(description courtesy of David Kee Toploaders)
Way Cool !!!
Co-founder of the Texas Cobra Club.
Dave "Ren Man"
