Old 09-02-2009, 08:23 PM
mickmate's Avatar
mickmate mickmate is offline
If you dimple in the rear inner fender as close as it will go to the tire that gives precious leg room. Seat track delete as mentioned. I just cut out and moved over a whole tunnel side on a CCX and made a custom header by the footbox. Also changed the shifter rods to go up and over instead of beside. That whole exercise gained a LOT of room. From there we pulled the wheel back about 1 1/2" and got a lot more knee room under it. The last trick was the owner (6'2" 280 lbs) took the seats right out and had a custom made cushion for bottom and back that goes right against the floor and bulkhead. He's a big guy that is racking up miles like crazy now.
mickmate
http://www.actoncustom.com/
