Old 09-03-2009, 09:27 AM
Default Different surfaces for the ports
UNDY Dave if you are running a wet manifold you will have a different surface finish of the ports. Wrench is running a dry manifold, a polished surface is better for flow, smoother is better. Have tryed rough surface, with a pcv valve working at the base of a Throttle body it slows the air flow and cokes up over time. Rick L.
