Old 09-03-2009, 02:58 PM
Tom Kirkham Tom Kirkham is offline
CC Member / Sponsor
Originally Posted by vector1 View Post
wbo2 helps tremendously in tuning.
This is so true. Without a wide band O2 sensor your are really fighting an uphill battle.
Are you running vacuum advance? vacuum secondary carbs? Big cam? What is your initial and total timing? Progressive linkage? Does your linkage bind? Can you post a picture of your engine? How is your fuel pressure?
If your carb is adjusted correctly, you should not be able to feel the transitions...
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
