Old 09-04-2009, 02:45 PM
Merv and Sharon's Avatar
Merv and Sharon Merv and Sharon is offline
Thanks guys. It is very well done as these guys know their job.
Yep, all holes drilled after painting and I did the larger ones for the hood mount socket behind the door. Easy really - use some good masking tape on the area and then a small drill bit and work up to the size you want. Use a plastic tube sleeve over the drill bit to control depth so you don't go to far with the drill - if that helps. Remove the tape and clean as a whistle!
The other imperative is to ensure the edges are trimmed with a soft material so as not to damage the paint and that the tonneau/hood does not leave a gap over the rear wheel arches where water can just flow in! Needs an appropriate pattern of fasteners. Lift a Dot posts at all four corners and in the centre. Zip is from a yacht shop.
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
