Old 09-06-2009, 05:07 PM
Default Do you have a return line?
Argess My ERA has a return line. Is yours not hooked up? Do you have a pressure regulator in the fuel system? If it does the pressure will bleed off in 3-5 seconds. If not it will bleed back through the fuel pump if there is no check valve in the system. You need to check the car out. Rick L.
