Old 09-07-2009, 10:35 AM
Default Avivad oiling system
67FEfastback Avivad sells a complete setup for and FE motor. Brackets,spacers, pulleys, tanks, and belts. The pumps are trick too if you want to run a P/S pump behind the oil pump. Dove sells an drysump with internal oil pump. You will need to find a place in the r/f corner under the hood for this setup. I am not a fan of runnng 10-14' or hose to the trunk for the supply tank. Rick L. Ps. Look at Peterson pumps also.
