Old 09-07-2009, 01:32 PM
undy's Avatar
undy undy is offline
What manufacturer and model alternator are you currently running? A lot of Cobras run the GM alternators, especially the 1 wire ones. Your alternator sounds like it's definately bad. My GM 100 amp 1 wire puts out 13.8 VDC @ 65 amps, at an idle. Mine's also convertable to a 3 wire setup. Doing so will give me the full 14.5 volt alternator output. Mine's a Powermaster. I plan on doing the mod in the near future in conjunction with my new cooling fan install.
Also, make sure your charging circuit/wiring is up to the task of a 100 amp alternator. Painless wiring and others typically are not. I run a #4 copper wire from my alternator to my fuse block/starter/battery and #8 copper to my engine cooling fan.
Too many toys?? never!
