Thread: engine timing
Old 09-08-2009, 06:15 PM
olddog olddog is offline
Not enough information.
EFI or carb?
What type of distributor/ignition system?
Does the distributor have vacuum advance?
If you have an old style carb and distributor:
You want 10 - 16 initial depending on cam. 10 for mild cam; 16 for radical cam.
You want 32 -36 total (mechanical + initial) all in by 3000 - 3500 rpm.
Vacuum should add 12 deg at 3 inches of vacuum less than the vacuum your engine idles at.
Note initial is set with vacuum disconnected and plugged.
