Thread: TKO600 clutch
Old 09-10-2009, 04:46 AM
patrickt patrickt is offline
Originally Posted by elmariachi View Post
The McLeod PP came with 5/16ths grade 8 bolts, and McLeod said to mount them with blue Loctite and NO washers, so that's what I did.
They provided their own fasteners? Do you happen to remember whether they were shouldered bolts? The only reason they would specify no washers would be to increase the fastener depth (which would seem to indicate they are aware of the issue). It would be nice if someone with a Fidanza aluminum flywheel could measure the depth of the shoulder hole and post it. From the factory, did Ford PPs come with washers under the PP bolts?
