Thread: TKO600 clutch
Old 09-12-2009, 05:15 AM
patrickt patrickt is offline
Originally Posted by RICK LAKE View Post
You are worried about your bolts in your clutch, you should see the small ones now being used in the new stuff. 8 & 10MM heads on a 1/4" -5/16's thread. ... I use the washer on my bolts and have no problem. In the old days there was a steel ring that the bolts of the flywheel went through to not gall the surface of the flywheel. I never found loose bolts on one of these motors with 20-50 thousand HARD miles. ... I believe in ARP bolts, nuts, washers, and other fasteners. I have used them on motors for more than 30+ years.
If anything, Rick tends to fall on the "alarmist" end of the mechanic's spectrum. For him to allay our fears of the ARP bolts speaks volumes. Just periodically stick a torque wrench in the fork hole and make sure they're snug -- that's all you need to do. And if you've been running non-shouldered Grade 8 bolts without a hitch for a couple of thousand miles, I don't think you need to change them out either. Rick is great -- Rick is my hero -- I love Rick.
