Old 09-12-2009, 05:52 AM
jhv48 jhv48 is offline
Default SPF Side Pipe Collector
Ok, I have read all the posts about replacing the restrictive side pipes in order to let my engine breathe properly.
However, I have a couple of choices to make. First, do I cut the existing pipes at the muffler and simply weld in a 3" replacement muffler (keeping the cost waaaay down), or do I have to cut the pipes at the junction of the four pipes and the collector and replace that too?
I guess what I'm asking is: Is there going to be a flow problem with the existing collector into the "new" larger muffler, or should I just remove the old side pipe entirely and replace it with a complete new unit from one of the vendors (most expensive).
Will the existing collectors screw up the exhaust flow into the new larger mufflers?
Jim
