Old 09-12-2009, 01:06 PM
blykins blykins is offline
For a 408, yes it is. However, there are street roller grinds around that duration that aren't that hard on lifters/springs. It all depends on what the duration at .200" lift and the advertised durations are.
Comp's street roller grinds have about 38-42 degrees between advertised duration and .050" duration, which isn't bad for a solid roller. They also have less duration at .200".
You can run these cams without wild spring pressures and I wouldn't care a bit to run one in a street car.
Comp also has some wilder lobes (take the TK lobe for instance) with around 28° difference between .050" and advertised durations. They also spend a lot of time with the valve open and then open/set it down fast/hard.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
