Old 12-01-2001, 09:21 PM
Sonny Sonny is offline
Default Jag 3rd member
fordracer,
ron used the 1.876" dia input/pinion shaft in all his cobras in lieu of the 1.423" dia ones. if this is what you have the torque range on input is between 360 to 410 lbs torque when converted from the uk id charts. MAINTAIN the non sulphur rear lube as recommended and you should be fine, even with 10" street/slicks.
SonnyB
