Old 09-13-2009, 08:15 AM
flapjack flapjack is offline
Default Road force measurement balancing
Hi All,
This is my first post. I worked for an Audi dealer up until recently and now work for a Lexus dealer. Chances are that there is some runout in either the tire or rim. A Road Force measurement of 6lbs is exceptionally good. I would ask the service rep. for an explanation as to what is marginal. Chances are it will be fine at 6lbs. I would only suggest R/forcing a wheel assembly after a tire has seen some use. Tires take time to seat properly and to break in. I have done comparisons regarding this. Also make sure that when mounting tires that both the rim and tire bead are both lubricated and inflate to no less than 40 lbs. when seating. You would be surprised as to how many times a new tire shows poor Road Force measurements due to the fact it was'nt seated properly.
Good Luck,
Flapjack
