Old 09-14-2009, 08:07 PM
tamanaco's Avatar
tamanaco tamanaco is offline
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Hey Cobred...great info. the good new is my tires had about fifty miles on them before road force balance.
Fastd...It almost goes is gone at 68 -70 ish.
I spent 5 hours today, measuring wheel runout, checking for loose, bent, not looking correct items on the front supenion and talking to a few people and Reg at Backdraft on what could cause this. The car alignment was checked and a slight toe in adjustment was made. What I have found was the right front tire showed much more wear, the small tits (the air vent holes that fill with rubber) were gone and edges on the forth tread rib were worn. The left front tire still had it tits and looked good. The tires only have 200 miles or so. Further inspection (by luck) showed the right strut (w/o spring loading) moved freely at the bottom inch of travel. Don't think a strut which is shock it should now do it. So, a new strut is going to be installed. I hope this solves it.
I've be chasing a tire and balance issue, now it looks like it be a bad front shock/strut. WOW
I'll keep
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
