Old 09-15-2009, 10:19 PM
From what I understand the Shelby block also requires significant machining prep prior to the build.
The rear main seal leak problem had something to do with not enough drain back around the seal area. I believe the solution was to simply drill some holes to relieve the build up of oil in that area.
