Old 09-15-2009, 11:42 PM
Hray Hray is offline
Cobra Make, Engine: classic roadesters ltd, 302, T5
Default todays progress report:
I stopped by and purchased a upper radiator hose, and got it installed. Cost 28 bucks. Haven't a clue what it was intended for. they guy let me go in the back and just match up something that I thought would work.
I put the filler neck just above the water pump in the upper hose, I guess it will work ok there.
Fired up the engine for a few seconds. Then finished polishing the first wheel, and got about half way done with the second.
I had a lower pully for serpentine belt, four bolt, and a belt 3 hole pully. I lined them up and redrilled the 3 hole to 4 hole. Fit perfect, saved some time and a few bucks in the junk yard.
Had to work in the office so only got a few hours this evening.
I also cleaned shop just a little, guess I have to count that toward the build, all part of it.
Gotta work tomorrow again, so only evening availble for the cobra. and 18.5 weeks till D day.
I will get those trans numbers later for the fluids.
I will provide more specfics of what I got with the car later in other posts.
Ray
