Do you have a fax machine around
Stentor I can mail you a copy of it. This is old info on this build and it was done in the 80's. It's about building a 600HP motor, we have 1/2 dozen builders here that are make 650 hp on street motors without the webers or Olbergs. Vacuum signal to the carbs at a steady rate is the most importnat thing and a good exhaust system with the right back pressure. Rick L.
