Old 09-16-2009, 11:00 PM
Hray Hray is offline
Cobra Make, Engine: classic roadesters ltd, 302, T5
Default update and rear end questions
the photo is of the rear end, will any ford drive shaft bolt to this rearend if it has the round type of ujoint housing.
also must I find a drive shaft from a 5 speed stick, or will automatic interchange. I know I gotta shorten it.
tonite I routed the bottom hoses, discovered I have a 3:26 rearend ratio in this. that should be a good road gear shouldn't it.
also look at my upper radiator hose routing is this a good place for the filler neck.
I now have 465 hours left to finish and 2800 left in the budget. and just over 18 weeks till autorama.
I did not want to bore you so i only pasted here my new flickr page, I posted more pics of the build, and some shots of my barn.
http://www.flickr.com/photos/belair567/
