Old 09-17-2009, 03:43 AM
blykins blykins is offline
Play in the rearend is normal, it's just gear backlash. It's difficult for us to give a unit of degrees as a standard, as backlash is measured in thousandths of an inch with a dial indicator on the ring gear.
However, if you were coasting to a stop, rearend play would not be the culprit here.
A chassis dyno would be a good way to check everything out, but I would look for something contacting/rubbing something else, or maybe something in the brake system.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
