Old 09-18-2009, 04:05 AM
Mando's Avatar
Mando Mando is offline
Your right Rob, I'm interested in the two 3/4 inch outlets on the pump. If I'm right, the top one is a bypass for water to exit the motor into the waterpump until the thermostat opens. That means water is going into the waterpump under pressure. Which way is water flowing through the lower outlet? You can see what I'm trying to describe in the picture.
Regards.
Mando
