Old 09-18-2009, 07:22 AM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
Originally Posted by Bobcat View Post
Fred ... my car is ERA 757 , .... I blocked off the oil cooler this summer and ran oil temps in the 140 to 180 degree range when just cruising . If I get on it , they will go to the 200 degree range .... and our ambients down here in summer are in the mid 90 to upper 90 degree range . Since we haven`t seen any cooler weather yet ( still in the upper 80`s ) , I don`t know what the oil temperature will do in cold ( for us ) weather. Our typical winters are lows in the low 30`s and highs in the mid 40`s . I made a cardboard template and then cut a piece of 1/8" Lexan out for the shield so the oil cooler could still be seen . I followed Doug`s advice and put a small piece of tape on the oil temp. gauge to remind me the cooler was blocked .
Bob
Thanks for the suggestion Bob. I like your approach and will see how things work out when I block the oil cooler inlet and drive the car.
- Fred
