Old 09-18-2009, 09:16 AM
tcrist tcrist is offline
I have a roll bar and head rests. Hope that I do not ever need to use them for anything other than looks. The question is, How would you install the rear down tube if the mounting bracket was welded onto the frame? The only way that I can install my down tube is from inside the fenderwell after the front hoop is installed and tightened down.
I guess everyones are different, so that is an individuals/manufactures own issue. I am sure there is a fairly easy way. I just need to figure it out.
The one thing that needs to be I guess is if you need to mount anything like that to the frame, make sure that you weld in a sleave through the frame so you do not start crushing the walls of the tubing when tightening the bolts.
Terry
