Thread: Port alignment
Old 09-19-2009, 10:14 PM
rokndad's Avatar
rokndad rokndad is offline
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
Originally Posted by Rick Parker View Post
Has anyone else noticed any misalignment with the IDA carb bases (throttle bores) and their manifold? My manifold aligns perfectly with the ports on the heads but leaves a lot to be desired between the carbs and manifold. I'll deal with it this Winter. It will require Filler and grinding to gain correct alignment.
Hey Rick. RE: port alignment, I too had always thought that a good port alignment and polishing job would mean increased HP through better unobstructed flow into the intake area of the combustion chamber. However, with these Weber IR intakes, there is no area for the emulsified fuel mixture to further completely mix with the turbulence you get from the runners in a traditional intake manifold. What I read said that some of the non-emulsified fuel droplets don't get efficiently burned in the cylinder since they are still liquid and not a compressible vapor. I know this sounds like splitting hairs, but it actually said not to try and make a smooth transition between the intake and the head to create a little turbulence to further along the mixing and emulsifying prior to entering the valve. I don't know, have you ever heard of this? And forgive me, I don't recall where I read it. My carbs and the intake align pretty closely. The head/intake is not.
