Old 09-20-2009, 03:47 PM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
Originally Posted by RICK LAKE View Post
fkemmerer Fred my motor like yours is all aluminum and we both run a FI system in our cars. I have the opposite problem of running too hot. I modifiled a 180 thermostat from a dodge bb to keep my temps in the 190's to 210 range after being on the track. Oil temps are in the 220f. I run the rotella 15-40 with lucas oil suppliment. I do have the twin fans in the nose instaed of the splitter. They look good but do little to move the air.
Have you thought about have a cooler added into the radiator and keeping the front mounted one for looks? Raising the coolant thermostat to a 195f may also help.
I can't get over that your motor can't get hot enought and mine I can cook eggs on in just 5 minutes. This is also with the ERA street pipes. I have heat shields and fire barriers through out the car. A paxton hood pulls in air by the ton. I added to 4" fans to help remove the heat from the engine compartment out the side louvers. I swapped from the copper rad to the Aluminum Griffen one. The only thing I have not added is a fan schroud.
On a side note, how is the traction control working? Rick L.
Rick,
What does your ignition timing look like at light loads and lower RPMs? I've found that not running enough can make a motor run very hot. I am running somthing like 34 degrees at idle (this may be too much depending upon your cam).
BTW, I am running ERA's radiator, their HD electric fan and the 2 small fans in the noise with no divider. My water temps will creep up to maybe 195 to 200 degrees if I let the car idle for awhile on a very warm day. I think that this is pretty much normal. Problem I have is getting the oil up to temperature.
Haven't gotten to the ETC yet. I have competition tires on my car so I have relatively good traction in low gear. I want to get everything else right with the motor, then do a full dyno tune on the car, and the last step will be the ETC calibration.
- Fred
