Old 09-22-2009, 05:03 PM
patrickt patrickt is offline
Ernie, I've never replaced the gear around the flywheel, but don't you have to remove the flywheel to do it? If your engine was zero balanced, without the flywheel on it, then you'll want to have your repaired flywheel & clutch assembly balanced as well as a unit. You are replacing your clutch, since you have it out, right?
