Old 09-22-2009, 06:39 PM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
Well, I'm back to the wandering tach needle problem.
At Doug@ERA's suggestion, I jumped the ballast resistor and then tested the tach. It actually seemed to help, but didn't rectify the problem. As I climb in rev's the needle stops going up at about 3000 rpm, even though I'm obviously spinning the motor faster.
I did buy a new tach---which I haven't yet installed. I think tonight I'll put the ballast resister back in line and then wire the tach directly and see if it reads differently than the installed tach. I don't recall if the current tach as the rotary switches or the DIP, but the new one definitely has DIP switches to select the number of cylinders.
DD
Dangerous Doug
"You're kidding, right?"
