Old 09-23-2009, 09:21 PM
RodKnock's Avatar
RodKnock RodKnock is offline
Originally Posted by Stentor View Post
Rod,
Based on conversations with various folks (e.g., Inglese, Pierce, Keith Craft) as well as calculations using information and algorithms from a variety of sources, the optimum choke/venturi size for Webers on my 511 ci FE is between 49 and 52. The 48 mm Webers would not accommodate this large of a choke (from what I've been told for a street car it's not practical to go above a 42 choke with 48 mm IDAs--as low-end performance will suffer).
Furthermore, the estimated HP loss from switching from a carb to 48 IDA Webers on my engine ranged from 60 HP to 150 HP (something on which I didn't want to compromise).
The good news is it looks like the 48 IDA FE manifold is going to work just fine with the Berg 58 mm IDAs.
I will keep folks posted.
Stentor
Yes, please keep us posted. While I think the 48's would be enough for my 482, I wasn't aware that you have a 511. More cubes is definitely a good reason for the bigger IDA's. Thank you for sharing.
