Old 09-24-2009, 02:55 AM
Default YOu are correct about the bolt pattern
Al I got gaskets from the friend that has 48 and 58 MM base gaskets. I see now that the bolt patterns are the same from point to point. There will be alot of grinding to get the openings to match and in some spots a very narrow piece of mount surface left to work with. Vacuum issues may be a problem over heat cycles. Time will tell. Rick L.
