Old 09-24-2009, 09:40 AM
DAVID GAGNARD's Avatar
Brent;
The cam card for the Comp cam is the one I've been using for 4 years now...very pleased with it, peak hp was 472 @ 6400prms and torque was around 420 @ 5700 rpms, idles nicely at 900 rpms and if I remember correctly pulled about 12 to 14 inches of vacum @1000 rpms....
I'm building a "new" motor, using the new BOSS 302 block with t he same heads and rotating assy., was planning to go to a more aggresive camshaft, been looking at other solid rollers in the 600 to 625 lift range.....
This is the Lunati Voodo cam I'm currently looking at, not 100% sure I'll get this one, but the specs are in the ballpark for what I want...
I'd have to check my notes, but I think with the setup I have I have enough piston to valve clearance for a max lift of around 675, my springs are good for 725 lift.....I was gonna go with no more than 625 lift just to give some added clearance.......
not having any luck posting cam cards, but here is where you can veiw them........
http://www.lunatipower.com/CamSpecCa...rtNumber=63032
http://www.compcams.com/Cam_Specs/Ca...?csid=830&sb=2
David
DAVID GAGNARD
