Old 09-24-2009, 02:33 PM
A98Coupe's Avatar
A98Coupe A98Coupe is offline
Cobra Make, Engine: #535 Kirkham 427, 427 Side Oiler
Seems like Tom is too busy to give you a straight answer, so here goes.
My car came with the same -6JIC TFE fuel hose from the Holley fuel pump mounted near the diff., intended to connect to the mechanical pump on the FE motor. I followed Kirkham's advice and installed a Mallory 4309 bypass type fuel pressure regulator on the rear of the inlet manifold using Kirkham's special throttle return spring bracket.
However, I used the existing fuel hose as the bypass return to tank by simply disconnecting from the fuel pump discharge and connecting to the spare port in the fuel tank (next to the suction port). I then connected the other end to the bypass port on the Mallory pressure regulator - the hose was exactly the right length!
I then ran another -6 fuel hose from the Holley pump to the mechanical pump and then piped from the mechanical pump up to the 2x4 fuel log. I modified the rear of the fuel log to take a straight -6JIC male fitting so that I could connect up to the Mallory pressure regulator. I've attached some pictures in the hope that this will help.
